- This topic is empty.
AuthorPosts
14/07/2025 at 13:53 #5280
Recently, the 8T 18M telescopic boom marine crane independently developed and produced by HAOYO has undergone comprehensive and rigorous factory testing and successfully passed various technical inspections, officially announcing the successful completion of the test. This not only marks another technological breakthrough for HAOYO in the field of ship and port loading and unloading equipment, but also demonstrates our firm commitment to providing customers with efficient, safe and reliable solutions.
1. About HAOYO
HAOYO is a professional manufacturer of ship and port loading and unloading equipment. We provide you with reliable, innovative and customized products. The sales and design departments are committed to creating suitable products according to the unique needs of customers. Our employees are committed to ensuring that the product structure is strong and performs well in every detail. The hydraulic department selects stable and high-quality systems to ensure that all products are always in good condition.
In the process of continuous development, HAOYO has always adhered to the concept of "quality first, customer first, innovation-driven", and has won the trust and praise of many customers through continuous technological innovation and strict quality control.
2. Introduction to 8T 18M telescopic boom marine crane
The 8T 18M telescopic boom marine crane that completed the test this time is a high-performance lifting equipment developed by HAOYO for specific working conditions of customers. The following are the main parameters and highlights of the equipment:
Lifting capacity: maximum rated lifting weight 8 tons;
Working radius: the maximum operating radius of the telescopic arm can reach 18 meters;
Installation method: deck installation, suitable for various ship types;
Drive mode: hydraulic drive, smooth movement and high efficiency;
Control system: equipped with advanced electro-hydraulic proportional control system, which can achieve precise operation;
Safety configuration: equipped with torque limiter, overload protection, emergency stop and other multiple safety protection measures.
This crane adopts a modular design concept, and the telescopic arm structure enables it to flexibly adjust the working radius according to actual operation needs. It can not only complete the lifting task in a limited space, but also extend to a farther operation area, greatly improving the operation efficiency and flexibility.
3. The whole test process
At HAOYO, we are well aware that the working environment of marine equipment is very harsh. Therefore, every crane shipped out of the factory must go through a strict testing process to ensure that it can operate long-term, stably and safely in actual work. This test work is divided into the following stages:
Static load test: Under the maximum working range, lift the rated load according to the specified safety factor, keep it for a period of time, and check whether the structural parts are deformed, whether the welds are cracked, whether the hydraulic system is leaking, etc.
Dynamic load test: Simulate the actual operation process, multiple lifting, rotation, amplitude change, telescopic and other actions, to detect the dynamic stability, response speed and coordination of the equipment.
Hydraulic system test: Detect the working status of the hydraulic pump, valve group, cylinder, and pipeline, confirm whether the pressure, flow, and temperature are within the normal range, and check whether there is leakage or abnormal sound.
Electrical control system test: Check the sensitivity and reliability of the electrical control system, including whether the manual/automatic control mode, emergency shutdown, alarm system and other functions are normal.
Safety protection function verification: such as whether overload protection, limit protection, buffer device, etc. are effective.
Appearance inspection: Check whether the details such as paint, logo, guardrail, lighting, etc. meet the standards to ensure beauty and safety.
After these tests, all performance indicators of the 8T 18M telescopic boom marine crane met the design requirements and finally passed the factory acceptance smoothly.
4. Technical highlights and advantages
The 8T 18M telescopic boom marine crane completed in this test not only meets the needs of conventional operations, but also has the following technical highlights and advantages:
High flexibility: The telescopic arm design gives it excellent working radius adjustment ability, which can operate in a small space and cover a larger range, and flexibly adapt to various working environments.
Convenient operation: The humanized operation interface, combined with the advanced electro-hydraulic proportional control system, makes the operation more precise and stable, reduces the difficulty of operation, and improves work efficiency.
Safe and reliable: All-round safety protection design, torque limiter, overflow protection, emergency shutdown and other devices effectively ensure the safety of equipment and personnel, and meet the safety standards of classification societies.
Strong structure: Made of high-strength steel and high-quality hydraulic components, the whole machine has good rigidity and durability, and is suitable for the harsh environment of high salt spray, high humidity and high corrosion at sea for a long time.
Easy to maintain: Modular design and reasonable layout facilitate daily maintenance and maintenance, reduce downtime and increase service life.
5. Market Prospects
In recent years, with the rapid development of the global marine economy, the demand for high-performance marine cranes in industries such as marine transportation, offshore wind power, marine aquaculture, and deep-sea scientific research has been growing. In particular, telescopic boom marine cranes have broad application prospects in the following fields due to their flexibility, efficiency, and space-saving characteristics:
Port and terminal logistics: efficient loading and unloading of cargo between large cargo ships and ports.
Marine energy development: support the lifting operations of energy development equipment such as offshore drilling platforms and wind power installation ships.
Marine scientific research and environmental protection: lifting of precision instruments and equipment on scientific research ships and scientific research ships.
Special ships: such as rescue ships, fire boats, patrol boats, etc. require fast and flexible lifting equipment to complete diversified tasks.
It is expected that with the recovery of the shipbuilding industry, the increase in marine economic investment, and the improvement of environmental protection standards in the future, the market demand for high-performance, intelligent, and environmentally friendly marine cranes will continue to grow.
The smooth delivery of the 8T 18M telescopic boom marine crane is not only the result of the unremitting efforts of the HAOYO team, but also the fulfillment of our promise to customers. In the future, HAOYO will continue to be customer-oriented, continuously improve product performance and service levels, and help the global marine engineering and port logistics industry take off.
If you have any needs or questions about ship lifting equipment, please feel free to contact us. HAOYO looks forward to working with you to create brilliance!
http://www.haoyotech.com
haoyotech
AuthorPosts
- You must be logged in to reply to this topic.
